a4 conversion
Old Mar 27, 2008 | 09:02 AM
Ronnie_W's Avatar
Ronnie_W
Default a4 conversion
I have tried searching and haven't found what I need. I will be changing my Z06 over to an A4 soon and am trying to gather information before I start. First, is there a write up that someone can point me to? I am wondering if all the wires/connectors ,for the wiring harness, that came with the transmission connect to my stock ecu? A diagram would be great to have. I am also considering maybe putting in an after market transmission controller to get around the stock wiring harness. What plugs in to the shifter to release if from park? I'm sure this comes from the brake, but I was wondering if it goes through the ecu or what. Maybe that is in the wiring harness? That is another concern if I go with an after market controller.
Do I need to change the radiator to one that has connections for the trans fluid lines?
I'm sure there are other concerns that will come up during the change over. I will be changing the engine to a forged 347 and adding an APS twin turbo when I start the work.
Old Mar 27, 2008 | 10:44 AM
BlackZ06's Avatar
BlackZ06
First, you need to purchase the Service Manuals for your Model Year. There is no way you will accomplish the swap asking a few questions on the forum .... you are looking at a significant project.
Second, it is unlikely you will find a "write-up" on this, it is way too expensive (and complex) a swap for a "shade tree" mechanic. I believe RPM Transmissions has done a few of these, but since it is how they make money it is unlikely they will "share" how it is done.
Finally, unless you plan to keep the car "forever", putting an A/T in a Z06 is going to hurt resale value, if not make it almost impossible to sell. Certainly you will never recoup the cost of this conversion in the sale price. I'd STRONGLY recommend you consider selling the Z06, buy a C5 (or C6) with an A/T, and the money yyou would have spent on the conversion can now be spent on engine and suspension mods to make the car "equivalent" to a Z06 ... a way cheaper way to go.
Old Mar 27, 2008 | 11:00 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
several members in the C5 ZO6 section have completed this swap.
look here:
http://forums.corvetteforum.com/show....php?t=1916615
and here:
http://forums.corvetteforum.com/show...t=transmission
Old Mar 27, 2008 | 11:05 AM
Ronnie_W's Avatar
Ronnie_W
Thanks for the input I don't plan on selling the Z06 and I understand the cost, resale value and all that. I know there are a lot of shade tree mechanics that have done this swap and I will be another one to do it. I already have all the parts I need to do it. I am just looking for a little information to make it easier once I start. This is the tech forum, right!
Old Mar 27, 2008 | 11:09 AM
Ronnie_W's Avatar
Ronnie_W
look here:
and here:
Thanks, I read all that during my search. I may be better off posting this in the FI section. You get a lot more tech stuff there for the heavy duty tech stuff.
Old Mar 27, 2008 | 11:12 AM
BlackZ06's Avatar
BlackZ06
look here:
and here:
To be more accurate ..... several members have "paid RPM Transmissions" to do this swap ....
I have yet to see a forum member post that they have done this conversion themselves, let alone post a "how-to" on the steps involved ....
Old Mar 27, 2008 | 11:15 AM
BlackZ06's Avatar
BlackZ06
If you "know" the conversion's been done by "shade tree mechanics", contact them and with the help of the Service Manual's .... have at it .....
Old Mar 27, 2008 | 11:31 AM
Ronnie_W's Avatar
Ronnie_W
Thanks again for your input. If it keeps coming like this, I will be able to do the conversion by the end of the day.
Old Mar 27, 2008 | 11:47 AM
BlackZ06's Avatar
BlackZ06
Just don't rip the VSS wiring out when you drop the differential this time ....
I gave you reasonable advice .....
STEP ONE - BUY THE SERVICE MANUALS
They contain the wiring diagrams so you can see what the differences are between the A/T and Manual wiring harnesses, the manuals explain how the PARK interlock works, and shows the differences in the plumbing for the ATF cooler system.
The manual's will answer 90 percent of your questions .... they are thousands of pages .... not only showing explanations and drawings of mechanical systems, but also with explanations of how the A/T and the PCM interact to shift the transmission.
Without the manuals, how is someone supposed to explain to you the differences in the wiring diagrams ???? There are hundreds of pages of wiring diagrams for the C5 ... this is not a 1968 SS 396 Chevelle, this is a car controlled by a number of computers, and to further complicate matters, has a "plastic" body making grounding of electrical componenets an important issue.
ORDER THE MANUALS and then you will have some idea of what you are facing ...
Old Mar 27, 2008 | 12:11 PM
Ronnie_W's Avatar
Ronnie_W
I think I'm doing pretty good! I've only ripped the VSS out once out of 4 times of dropping the tranny/rearend. I know the service manuals are a good idea, but I was hoping to get the readers digest version before going that route.
Old Mar 27, 2008 | 12:16 PM
tiojames's Avatar
tiojames
Can't comment on the rest of the swap, but you can install an after market cooler. Since you are going twin turbo I would recommend an after market twin tube radiator and you could order one with the tranny cooler in it. As suggested above, post in the FI section also.
Old Mar 27, 2008 | 12:24 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
I agree with buying the manuals, but i disagree that this could not be done by a "Shadetree". If you take your time, utlize the books and maintain good attention to detaile, i have no doubt this could be done at home.
Ronnie, if you run into any sticky spots or need some information, give us a call id be glad to help answer any questions you might have.
Old Mar 27, 2008 | 02:44 PM
BlackZ06's Avatar
BlackZ06
My definition of a "shadetree" mechanic is someone who can obviously replace spark plugs, change oil, even replace a water pump. It starts to get kinda "grey" as to whether a "shadetree" mechanic could replace their own clutch on a C5. Swapping out an MM6 for an M30 (4L60E) is NOT a "shadetree" mechanic.
Can someone do the swap "at home" ... sure .... but keep in mind you not only have the mechanical issues, but wiring issues, and issues such as dealing with the fact the current PCM is programmed for an M6 tranny ... what ya gonna do ... reprogram or replace the PCM .... and in replacing you gotta update the VIN in the "new" PCM (if you don't you'll get stuff like a B1001 which disables your airbag system) ..... OR go with some third party tranny "controller" and figure out how to integrate that into the car .... hardly "shadetree" mechanics ......
Again, I'll state that other than posts referring to RPM having done a VERY few swaps ..... please show me where an "individual" has done this swap ..... even RPM wants the car for days to do the work .....
Old Mar 27, 2008 | 03:21 PM
Former Vendor
The defenition of a "shadetree" is defenetily a matter of opinion, not disputing you there.
The swap is not hard, time consuming, yes. But it can be done. Believe me i understand what is entailed. What i dont get is discouraging someone from doing something on thier own just becouse you havent seen one done at home on the internet, and why go to so much trouble to try and talk him out of it?
I applaud anyone who does this type of work themsleves, there is nothing more rewarding then modding your car yourself, and saving yourself thousands in the process
The mechanics for the swap are very straightforward, There is some wiring to take care of and of course the PCM and Vin, which will take any experienced tuner about 3 minutes to fix, so theres really nothing to stop him if he has the tools, the time, and the drive to see it through
Old Mar 27, 2008 | 05:01 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
It's not as big of a deal as you think, I know of two forum members who have completed this swap in their garages, the biggest part is the wiring under the dash and even it's pretty straight forward.
A service manual or access to the wiring diagram for the switches on the pedal assembly is mandatory, and the PCM can be sent out for reprogramming.
Old Mar 27, 2008 | 06:35 PM
red88L98convert's Avatar
red88L98convert
More power to you Ronnie. Do what you want with YOUR car. If you are keeping it, who cares what you change or how you customize it. Shoot, if resale doesn't matter to you, who cares if you are planning on selling it.
It's too bad some people on the forum feel the need to blast you for changing parts on your own car.
I would guess that every tuner or shop had to start somewhere and do a job the first time.
Old Mar 27, 2008 | 07:13 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
If you find someone to do the swap. I have an A4 and 3:73 If you will put your trans in mine
To a4 conversion
Old Mar 27, 2008 | 07:38 PM
Mike Mercury's Avatar
Mike Mercury
he's never asked "if I should" ... it's very obvious that decision had already been made. What he's asking is "how to".
Old Mar 27, 2008 | 08:31 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Makes good sense
Old Mar 27, 2008 | 11:04 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Just curious, What do you plan to use your car for primarily? I know the C6-Z cars have a completely different frame that's significantly lighter but I'm not sure how much the C5-Z differs from the C5 Base.
