C6 VS C6Z shifters?
Old Mar 27, 2008 | 10:53 AM
VIPERBLUELX's Avatar
VIPERBLUELX
Default C6 VS C6Z shifters?
Is there any difference at all between the two?
Old Mar 27, 2008 | 12:16 PM
hotwheels57's Avatar
hotwheels57
Rubber bushings vs metal bushings...on the two TORX bolts that secures the box beneath the shifter to the torque tube. Since GM sells the shifter as a complete assembly with the box, there are two part numbers.
Actually, looking at the C5/Z06 shifter and the C6/Z06 shifter, there seems to be no difference other than the square **** vs the ergonomic ****, the straight lever vs bent lever with the side fastener, the 9/16-18 threads vs the machined flat, the boots and the rubber bushings vs the metal bushings. Any shifter from either generation will interchange from '97 to '08 if those differences are acceptable to the owner.
Old Mar 27, 2008 | 01:54 PM
VIPERBLUELX
Which shifter would this one be?
Old Mar 27, 2008 | 02:22 PM
hotwheels57
It would appear to be a C6 or a C6/Z06 shifter. There's no box beneath the shifter, so no bushings to differentiate.
I can detect the bent back lever and the side hole for the fastener of the ergonomic ****.
BUT someone could have drilled a C5/Z06 shifter for the side fastener, bent the lever and attached the C6/Z06 ergonomic ****.
Although, I don't think the ergonomic **** w/o threads will slip easily over the C5/Z06 9/16-18" threads...
Old Mar 31, 2008 | 08:16 AM
blackconv's Avatar
blackconv
Yes, it will. The C6 shift lever is actually a little thicker than C5. C6 **** on a C5 shift lever will actually be a little loose.
To C6 VS C6Z shifters?
