How to Adjust Your Convertible Top
Old Dec 10, 2001 | 05:57 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default How to Adjust Your Convertible Top
I've added how to do this on my site:
http://www.vetteguru.com
Old Dec 10, 2001 | 06:22 PM
nearthelimit's Avatar
nearthelimit
Default Re: How to Adjust Your Convertible Top (kewlbrz)
Very detailed and informative. Have made two of those adjustments on drivers side, but wasn't aware of others. Thanks. I'm copying all 13 pages while I type! JR
Old Dec 10, 2001 | 07:42 PM
B. Stewart's Avatar
B. Stewart
Thank you very much. Great illustrations and clear instructions. :yesnod:
Old Dec 10, 2001 | 07:52 PM
RAGGDOLL's Avatar
RAGGDOLL
Toronto Events Coordinator
Thanks...going into my tech binder right now...
Old Dec 10, 2001 | 08:45 PM
luvinc5's Avatar
luvinc5
Default Re: How to Adjust Your Convertible Top (mjager)
thank you so much! very informative article :yesnod:
Old Dec 10, 2001 | 09:50 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In IV Veteran
Default Re: How to Adjust Your Convertible Top (luvinc5)
:cheers: Even I understood it :yesnod:
Old Dec 10, 2001 | 10:35 PM
LtMash1A's Avatar
LtMash1A
I don't see it. I've pulled the site up 3 times.
[Modified by LtMash1A, 8:41 PM 12/10/2001]
Old Dec 10, 2001 | 10:48 PM
oceanaire's Avatar
oceanaire
Thanks KEWLBRZ!! :seeya
Old Dec 10, 2001 | 11:02 PM
LtMash1A's Avatar
LtMash1A
OK, Ok, I click on http//:www.vetteguru.com and its supposed to be there, underlined......right???
Old Dec 10, 2001 | 11:13 PM
chuckster's Avatar
chuckster
Shawn you are the man! :cool:
Old Dec 11, 2001 | 12:06 AM
3BVert's Avatar
3BVert
Thank you!
Old Dec 11, 2001 | 12:35 AM
kewlbrz's Avatar
kewlbrz
Default Re: How to Adjust Your Convertible Top (LtMash1A)
ltmash, its the link just below the 30# injectors.
here is the direct link.
http://www.vetteguru.com/top
cheers :cheers:
-shawn
Old Dec 11, 2001 | 08:05 AM
stevenll's Avatar
stevenll
Thanks Shawn.
Very informative and helpful post.
Len
Old Dec 11, 2001 | 02:11 PM
white top's Avatar
white top
Great info thanks. Question is there any adjustment to the topto prevent the back corner of the window from rubbing against the
top.
Old Dec 11, 2001 | 05:23 PM
kewlbrz's Avatar
kewlbrz
Default Re: How to Adjust Your Convertible Top (white top)
top.
As described in the link i posted. Adjusting the knurled **** may help, as would adjusting the rear pressure link bars. Adjusting the window tip in etc may help. Beyond that, its probably dealer time for a new top.
Old Dec 11, 2001 | 05:57 PM
LtMash1A's Avatar
LtMash1A
Thanks Shawn. I'm on my computer at work and can see it now. I think I need to change the settings on my computer at home since it is loading the old web page before the change. I'm working on getting my EASE program straighten out and will get the LTFT's done Friday if the weather is good.
Mash
Old Dec 11, 2001 | 06:03 PM
kewlbrz's Avatar
kewlbrz
Mash
clear your web page cache, or hold down ctrl and click on refresh, should load the new page.
let me know on the ltrims.
To How to Adjust Your Convertible Top
Old Nov 10, 2010 | 12:42 PM
Cscrib's Avatar
Cscrib
6th Gear
Default Convertible top issue
I have a 2007 Z51 convertible. The waterfall won't completely close when attempting to raise or lower the top. Consequently the top only half closes and when in the down position there is a gap in the waterfall. Any ideas?
Thanks!
Charlie
Old Nov 10, 2010 | 01:30 PM
dougbfresh's Avatar
dougbfresh
Thanks!
Charlie
Try the C6 section!
Old Nov 10, 2010 | 02:19 PM
Cscrib's Avatar
Cscrib
6th Gear
Thank you.
C.
