turn signal question
Old Mar 28, 2008 | 11:24 PM
rdbrn's Avatar
rdbrn
7th Gear
Default turn signal question
'01 convertible, how do I make access to the left front turn signal bulb?
Old Mar 29, 2008 | 02:26 PM
bluvette79's Avatar
bluvette79
if it is like the 99, you unscrew and pull down the lower cover below bumper and reach up to gain access. a little hard to see but i am no wrench and and that is how i got to it to change. be careful that you get the new bulb in tight because it may feel tight but it is not fully seated
good luck!
Old Mar 29, 2008 | 08:54 PM
docohm's Avatar
docohm
bluevette79 describes one way, you can also get to it from above if you're real careful and take off the cover around the headlight. to get the bulb out there's a tab to depress and then it turns. sometimes they are hard to depress so be careful....
good luck....
docohm
Old Mar 30, 2008 | 09:55 AM
bluvette79's Avatar
bluvette79
i have heard of that way but i don't know how to take the front cover off!
To turn signal question
