lowering
Old Mar 29, 2008 | 02:47 PM
mikein707's Avatar
mikein707
3rd Gear
Default lowering
What is the best, cheapest and easiest way to lower a C5?
Old Mar 29, 2008 | 02:57 PM
Brandon619's Avatar
Brandon619
It is easy cut the bushings here is a link.
https://www.corvetteforum.com/techti...D=90&TopicID=1
Old Mar 29, 2008 | 03:15 PM
mikein707's Avatar
mikein707
3rd Gear
Thanks that does look pretty easy.
Old Mar 29, 2008 | 04:42 PM
hotwheels57's Avatar
hotwheels57
The "best" is probably quality coil over shocks, but most chose the "cheapest and easiest" with oem or longer lowering bolts and/or cutting the bushings.
You'll need to get an four wheel alignment after you lower the car or you'll be replacing expensive tires faster than you'd like to.
If you lower to much, you'll need to think about changing shocks.
Old Mar 29, 2008 | 05:31 PM
mikein707's Avatar
mikein707
3rd Gear
Well I did the one side not cutting the bushing just tightened the lowering bolt all the way and it didn't make that much difference. I need a good two inches. How can I get that? Cutting the bushing would have given me only 1/2 inch.
Old Mar 29, 2008 | 11:02 PM
Tom Porter's Avatar
Tom Porter
Mine is lowered 1 5/8" in the front. I could only get that by removing the front bolts. Believe me 1 5/8" is pretty low for the front. My air dam is only 1 1/2" off the road.
To lowering
