Detonation at higher revs???
Old Dec 10, 2001 | 11:54 PM
CAracer's Avatar
CAracer
Default Detonation at higher revs???
I noticed over the weekend that my 01 A-4 was detonating in first and second gear in the higher revs. I understand detonation usually happens while under a load. At least this has been my experience in the past.
I would think that in higher revs the problem wouldn't be there. It was fairly warm (in the 80's), and here in CA the highest octane obtainable is 91...
The car is stock. Except for the following mods: MAf screen removed, 160 thermostat installed, Z-06 air box (K/N) airfilter and a gear change (3:42's).
Is this a timing issue or lean condition??? What's the correction? Can I pull up error codes and get a better understanding of what's really happening?
Thanking you in advance for any advise.
Old Dec 10, 2001 | 11:59 PM
robiferretti's Avatar
robiferretti
Default Re: Detonation at higher revs??? (CAracer)
detonation is usually a result of lower octane gas. most likely its nothing :cheers:
Old Dec 11, 2001 | 12:24 PM
Chris@SD's Avatar
Chris@SD
By your mods, it looks like you have increased the breathing capability of the engine by removing some of the restrictions, like the MAF screen, air box and stock air filter. You are essentially leaning your car out. The octane is not helping you either. I think a MAF-T coupled with a scanning software like the EASE software and a little time will cure your detonation problems.
Another possibility is some of the spark plugs may have lost their platinum puck in the combustion process. If this is the case, changing the plugs to a standard copper plug like the NGK TR55's will solve the problem.
It might be easier to start with the plugs as well as being cheaper.
Good Luck,
Old Dec 12, 2001 | 08:42 PM
CAracer's Avatar
CAracer
Default Re: Detonation at higher revs??? (Chris@SpeedDemon)
Chris, thanks for the advise. I will try changing the plugs first. The other option sounds expensive. Where can I take the car and have it done?
Thanking you in advance. John
To Detonation at higher revs???
