Transmission Or Clutch
Old Mar 31, 2008 | 09:32 PM
rrod100's Avatar
rrod100
Default Transmission Or Clutch
I need some help to figure out what is wrong with my 99 coupe 6 speed corvette. It has about 85K miles. It has been giving me problems when i put the car into reverse for sometime now. However recently reverse just does not want to go in. Before i just had to keep my hand on the shifter from having it pop out. These last few days i have not been able to get it into reverse. It makes a grinding noise when i try to put it into reverse. I have read some people's threads before and want to get some advice as to what might be causing this. Do i need to rebuild the Tranny or replace the clutch or maybe it is something else since all the other gears work fine. I would appreciate anyones advice.
thank you in advance .
Old Apr 1, 2008 | 04:41 AM
Corvette Don's Avatar
Corvette Don
Try to readjust the shifter linkage, do a search on it to find the steps, that may help with the reverse issue.
Old Apr 1, 2008 | 09:18 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It could be your reverse lock-out switch has gone bad.
You should not be moving when trying to put the car into reverse.
Do you get a grinding noise in any other gears ?
Old Apr 1, 2008 | 11:51 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Did you use Mobil 1 transmission fluid in it? I hope not.
Old Apr 1, 2008 | 01:51 PM
speedsk899's Avatar
speedsk899
It will destroy the paper blockers!
Mine does the same thing, I have to hold it in, It is more than likely the synchro, live with it or get it rebuilt! I know a guy that will rebuild it for $1250 with a one year warranty, and up grade it to carbon fiber blocker and such......
Old Apr 5, 2008 | 06:43 PM
rustyguns's Avatar
rustyguns
who is this guy? i may need a rebuild
Old Apr 5, 2008 | 08:31 PM
speedsk899's Avatar
speedsk899
Bobby's Transmission in Kinston North Carolina.....
To Transmission Or Clutch
