St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Alarm Activiation
Been working on my 2002 ZO6 and the battery went dead. Upon charging it (and still working a fuel issue) if I try to arm the alarm (lock doors etc) it goes off and has to be disarmed. Anyone ever have this issue. Thanks
First, have you checked to make sure the trunk lid is closed properly, doors are closed properly, Fuel filler door is closed properly .... if any of them are ajar, the "Content Theft Deterrent" (CTD) will alarm.
If that doesn't clear it, and you need to lock the vehicle ... from inside the vehicle ensure the passenger door is locked with the manual switch.
Step out of vehicle and lock driver's door using the key .... DO NOT USE THE FOB ... use the key .... vehicle should be locked with CTD disabled.
