I have the Summit UD pulley on my car.I installed it when I did cam in January 2008 and have put about 500 miles on it.Only thing was the instructions said to use the stock AC belt and it was to big. Had to replace AC belt and the instructions tells you what belt to use for the other belt and it was right.I have the belt #'s if anyone needs them.I will have to go to my shop to get #'s later.
I am running that Summit pulley as well. No problems at all. It has a keyway so you can pin it to the crank. As for belts, I used the stock size AC belt (4040420) and a slightly smaller main belt (4060775), both Goodyear Gatorback.
Interesting I used factory belt and didn't think I had any issues with them. Come to think about it I have been getting some extra chatter from the AC clutch, maybe the belt is to loose...
