Oil pressure sensor slow death?
Old Apr 2, 2008 | 12:30 PM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
Default Oil pressure sensor slow death?
Had the battery unhooked for my header install last weekend and did an oil change while I was in there (mobil 0/30 and delco oil filter). On the first test drive I notice higher than normal oil pressure 60-70 driving and idle low 60s. Today I drove it to work for the first time (30 miles), started the drive at 60psi, ended at 82 at idle. While driving the DIC reads as high as 101 at 2k RPM. I turned the car off and it reads 59psi with the motor off after 5 minutes.
Anyone ever heard of a pressor sensor going bad gradually like that? I always thought they were go/no go
The only issue with the oil change was that I had stab the old oil filter with a screw driver to get it to turn, nothing happened with the filter adapter or anything (just noting that).
Thoughts??
Old Apr 2, 2008 | 12:37 PM
Blackbird89's Avatar
Blackbird89
When I had one go bad, it read low, never high.
Maybe it got cracked, or isn't fully plugged in.
Old Apr 2, 2008 | 01:48 PM
JCSZ51's Avatar
JCSZ51
TTT, still got a 30 mile drive home today and I need a warm fuzzy
Will it live?
Old Apr 2, 2008 | 04:53 PM
joe_121212's Avatar
joe_121212
Mine went high to 80-90 and just stuck there. Lots of info on this in the forum. Lookup "Oil pressure sensor".
Old Apr 2, 2008 | 06:17 PM
JCSZ51's Avatar
JCSZ51
Already read every one of them
Confirmed sensor is dead! Slowly got to 130 and now stays there, changed oil and filter just for warm fuzzy and no change.
Looks like fast 90/90 time
Old Apr 3, 2008 | 10:21 AM
2fast4sanity's Avatar
2fast4sanity
When my oil pressure sensor went out, it pegged high and stayed there.
Old Apr 3, 2008 | 10:51 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yes, its dying as you suspect. When you get it out, you will probably find oil inside the connector. To be sure, turn on the ignition without starting the engine. If it reads something other than zero...sensor is done.
Old Apr 4, 2008 | 11:19 PM
JCSZ51's Avatar
JCSZ51
new ones in, and works perfect !!
Old Apr 5, 2008 | 04:51 AM
SpeedUp's Avatar
SpeedUp
My 02 is doing the same thing, just started tonight. Pegged a 90. Did you change it yourself? if so, what post instructions did you follow?
thanks!
Old Apr 5, 2008 | 10:33 AM
JCSZ51's Avatar
JCSZ51
thanks!
Did it myself after reading the sticky at the top of the tech section. Here's a link with my inputs at the end.
Good luck, it isn't bad.
http://forums.corvetteforum.com/show...588172&page=20
Old Apr 5, 2008 | 10:58 AM
JohnTheStigGalt's Avatar
JohnTheStigGalt
My 1st died by pegging; my 2nd died by going nuts for a week, then dying at 0... Haven't put the Buick one in yet...
Old Apr 5, 2008 | 12:26 PM
dgrant3830's Avatar
dgrant3830
If you all are buying sensors from a dealer and they fail right away or within a year, take them back. They are warrantied by GM for a whole year and its the only way to convince GM that they have a problem.
Old Apr 5, 2008 | 09:24 PM
SpeedUp's Avatar
SpeedUp
thanks! i changed mine today and the cut out method is the way to go. So easy to do. I recommend the dremel tool for cutting. The fiberglass cuts like butter.
thanks JCSZ51!
Old Apr 5, 2008 | 09:25 PM
JCSZ51's Avatar
JCSZ51
thanks JCSZ51!
That's what this forum is all about
Old Apr 5, 2008 | 09:26 PM
thetaxman's Avatar
thetaxman
I changed mine today and the cut out method is the way to go. So easy to do. I recommend the dremel tool for cutting. The fiberglass cuts like butter.
another convert
Old Apr 6, 2008 | 09:21 AM
rws.1's Avatar
rws.1
Mine died the same way last year...
first noticed the increase anfter an oil change and it went over the next few weeks...
To Oil pressure sensor slow death?
