Column lock fuel question
Old Apr 2, 2008 | 11:24 PM
flynlow32's Avatar
flynlow32
Default Column lock fuel question
I just read the stick about column lock and i do not know if my car has it done or not. Once in a while my car will say wait ten sec to start on the dash and im about to replace the fuel pump because im getting about 20 psi fuel when key is on and it drops off as soon as i go to start it. If my column lock has gone bad but my steering wheel still works, can this shut my gas off?
Confused by sticky.
Sorry,
Jeff
Old Apr 2, 2008 | 11:58 PM
Oldvetter's Avatar
Oldvetter
Yes, IF your locking plate was removed AND an earlier recall did the fuel stop flash, AND now your k-harness is malfunctioning, the fuel will cut off at 2 mph. BUT, you should get a "service column lock" message.
A few questions. Does your steering wheel lock when car is parked? If not, either the plate has been removed or a CLB installed. If it does not, do you hear a hum when starting car from the steering column? If you hear a hum, you have the GM recall.
The wait ten seconds can be caused by a dirty key. Try cleaning the resister chip in the key with alcohol. If this doesn't work, try using another key, sometimes they go bad. If this doesn't work, your ignition switch could be bad.
Old Apr 3, 2008 | 12:35 AM
flynlow32's Avatar
flynlow32
my car is an a4 2000 coupe. im not at the car right now but i do think the wheel locks when the car is shut off. If it shuts the fuel off, will the car still start and idle?
Jeff
Old Apr 3, 2008 | 12:36 AM
flynlow32's Avatar
flynlow32
Im guessing its my fuel pump but trying to rule everything else out before i replace it is all.
Old Apr 3, 2008 | 09:31 AM
BlackZ06's Avatar
BlackZ06
Since your "description" of your problem makes no sense at all ......
IF you are getting the SERVICE COLUMN LOCK message ..... your engine will start. Fuel will be supplied until your rear wheels reach a speed of 2 MPH, at that point the PCM will "turn off" the fuel injectors .... therefore shutting off the engine. This is programmed into the car so that it cannot be driven with the column in a "locked" state.
Old Apr 3, 2008 | 10:16 AM
jovette's Avatar
jovette
If you have low fuel pressure, I'd first change the fuel filter, before I'd go to the trouble and expense of fuel pump replacement. Believe you should have something like 38-40 lbs., not the 20 lbs. you reported.
Old Apr 3, 2008 | 02:05 PM
flynlow32's Avatar
flynlow32
Sorry for not making sense. I was in a hurry and appologize for sounding dumb. It has a new fuel filter on it and ran with the new one for about 100 miles. Im pretty sure it is the fuel pump and not a lock column issue since it wont even stay running at idle. The fuel pressure drops off as soon as it starts.
Thanks,
Jeff
Old Apr 3, 2008 | 02:25 PM
BlackZ06's Avatar
BlackZ06
Thanks,
Jeff
You've actually put a gauge on the fuel line to see what the fuel pressure is ??? You say in your first post that your fuel pressure is 20 psi ...... and later you say you have a new fuel filter installed .... then yes, sure sounds like the fuel pump in your left tank is bad.
My only caution is that the electric fuel pump in the left tank also feeds the right tank siphon pump, so it is possible the low pressure is due to a problem with the right tank fuel feed.
Replacing the left electric fuel pump is the most likely fix for the problem .... but it may not actually fix the problem.
Old Apr 4, 2008 | 09:21 PM
flynlow32's Avatar
flynlow32
Default Thank you!
I am replacing the whole left side fuel pump tonight. I hope this fixes it. If not...I will go for the right side as well. I bought a complete fuel pump because i was having issues with my gadge not reading as accurate as i would like it to. It read correct when you would start the car up but never seemed to move till you shut it off and when you turned it back on...You looked like you just lost a ton of fuel! I heard it was from cheap gas and a known issue so hopefully replacing the whole thing i can kill two birds with one stone.
The psi with the key just turned to the on posistion is 20 psi but as soon as you crank it, It falls off to less pressure. The car will start then just fall on its face and stumble and die. It cant stay running for more than 2-3 seconds.
I will keep you guys posted and let ya know if the LH side fuel pump fixes my issues.
Thanks,
Jeff
To Column lock fuel question
