remove stud from differential
Old Apr 3, 2008 | 04:33 PM
dbisch's Avatar
dbisch
3rd Gear
Default remove stud from differential
I am in the process of removing the diff side cover to replace a leaking o-ring. I am unable to remove the stud that goes between the transmission and diff side plate. As per GM I have put two nuts on the stud and tried to remove, but it will not come out. Liberal doses of PB Blaster have been applied. Any suggestions would be appreciated.
