"remove Key And Wait 10 Seconds".
Old Apr 4, 2008 | 08:11 AM
Mark F's Avatar
Mark F
Cruising
Default "remove Key And Wait 10 Seconds".
Hi guys,
My 99 gave me a new problem to think about last night.
When I started the car all was fine then the display message said to "REMOVE KEY AND WAIT 10 SECONDS".
I put the car in reverse and the engine died. I removed the key waited 10 seconds and restarted the can and went on my way.
This happened again the next time I used the car but did not happen thids morning.
What am I looking for here?
Thanks for any feed back
Mark
Old Apr 4, 2008 | 08:16 AM
Casem1's Avatar
Casem1
The first question to be asked "are you familiar with the column lock bypass?"
Let us know how much you know, then we can help.
Old Apr 4, 2008 | 08:20 AM
Mark F's Avatar
Mark F
Cruising
Negitive on the column lock bypass
Old Apr 4, 2008 | 09:45 AM
Darkhalf's Avatar
Darkhalf
Time to purchase a CLB. Read the very first sticky thread at the top of the tech page that will give you everything you need to know. Search button is your friend as well
Good luck!
Old Apr 4, 2008 | 10:00 AM
Casem1's Avatar
Casem1
$50 is a small price to pay to avoid being stranded in a parking lot (or worse)
http://forums.corvetteforum.com/show....php?t=1015483
Old Apr 4, 2008 | 11:07 AM
timemender's Avatar
timemender
Originally Posted by Mark F
Hi guys,
Mark
Clean the two pellet contacts on the key. Clean with alcohol or run a pencil eraser over the contacts.
Keep the key clean in the future to avoid dirt buildup in the key hole. Remember the key hole has electrical contacts that mate with the key pellet.
Dirty contacts result in faulty electrical readings.
To "remove Key And Wait 10 Seconds".
