TigerShark owners please help
There is no way it would fit using my stock adjustments. my hood wouldn't close without smacking the bumper.. so i removed it and brought the bumper adjustments all the way forward. (to increase clearance. After doing so and tightening the fenders back up i got great clearance.. the middle is a little tighter, but once painted i could live with.. however the problem now is the bumper sits higher than the hood in dead center.
The bumper adjustments are also at the lowest settings... we are talking maybe .2 of an inch high.. it slops perfectly with the hood and the headlights but sits high in the middle... did i get a bad bumper? is this normal for stock hoods? I plan to get a tigershark hood next month or so...
thoughts???????????????????????????????? ???????
oh i tried raising my hood a little... it didn't do me much good but sure did mess the alignment of the hood up around the fenders.
so thats going to have to go back down. oh i did notice on my stock bumper that it has a weird indent in that area... doesn't look like the factory makes it that way but maybe it was melted for a better fit..
i took a sheet of foam i had laying around. i folded it a couple times and set it between the bumper and the hood... perfect fit..
so how do i get the bumper to do this without the foam?
it's late and i'm tired... have drill again tomorrow so i'll post my results after removing/reinstalling tomorrow. ajg thanks for the advice
btw... i haven't checked up on your project in awhile.. hows it coming?
It's a lot easier when you have a second pair of hands. Doing it by yourself takes forever.
Check out this thread: http://forums.corvetteforum.com/show....php?t=1988759
He doesn't have a TS but it still will help a lot.
I hope to get up there in the next week or two to see how things are going. My work schedule has just been crazy.
I kept my old bumper for a couple reasons, i'm to lazy to take the lights out of it just yet and incase i ran into some problems i wanted something to compare with... well tonight i took my old bumper back down and place it on.. amazing how fast it wanted to line up... i guess being bolted up for 10 years will do that.
anyways... i did discover somehting that i found just amazing...
The bumper is too thick... what do you mean it's too thick? well i dont' have a gauge to give exacts but the part of the bumper the bolts up under the hood... it's about double the thickness of the factory one... which doesn't seem like a big deal but it is... just eye balling it... there is more excess bumper (compared to stock) then the amount of lower required to make it line up perfect...
I'm off to buy a better sander... i'm going to remove about half of the thickness from the bottom up... i'm going to take it mostly from the middle as the outsides line up just fine.. by removed that the bumper has to lower...
it's getting too late to be making that much noise here.. so i'll buy the tools and supples tonight and go right to work tomorrow when i get home.
Oh for those wondering what happened to grinding away the plastic bracket... Ya i did... alot lol... so much so that it's not even a factor in lower it anymore... the problem lies with where the clips are that the bumper bolts too... they are either too high still ( can't be lowered any further ). So thats how i've come to the conclusion that it's the thickness of the bumper that is the problem.. i'll try to take some pictures of the difference tomorrow before i start grinding away.
I had to shave some of the bumper reinforcement foam to get it to fit right.
but heres my thinking:
In the very middle and only in the middle the bumper sits about .1 of an inch to high. If you take your finger and pull it down the hood cross the gap to the bumper it fits fine from the headlights in... from dead center out 3 inches both ways (toward headlights) is where its.1" to high.
the only way i figure it, to change this I either raise the hood which will mess up the lines around my lights and the good parts of the bumper.. or to lower the bumper .1".
I've taken away enough of the plastic reforcement that it's no longer a factor. So the next place would be part of the of that plastic piece where the bumper bolts up under the hood. Because those can't be adjusted/or grinded away, the only way i can see to lower that part of the bumper is to remove some of the bumper.
I'm thinking if i just remove the material around the bolts and some inbetween that should be enough to lower the bumper into fitting perfect.
I'll take some before and after pics tonight.
of the grinding? yes... couldnt' get a picture of the problem with the hood/bumper.. i'll just paint on the picture to help illustrate where the problem was... i'm happy enough with the fitment to take it in for paint... but i have this nack for perfection... so i'm off to go back into my garage grind a lil more away so that the fitment is just right.. after that i'll put the lip in and take some pics... hoping to be done tonight so i can drop it off tomorrow morning at the shop for paint.
