Secondary Air Injection
Old Apr 5, 2008 | 10:55 PM
PewterMetallic98's Avatar
PewterMetallic98
Default Secondary Air Injection
Would a check engine light for secondary air injection cause the car to run RICH at WOT?
Old Apr 6, 2008 | 11:26 AM
FRCTony's Avatar
FRCTony
No.
Old Apr 6, 2008 | 01:28 PM
PewterMetallic98
Any idea on what would cause a stock Z06 to have that AFR?
Old Apr 6, 2008 | 03:53 PM
juha_teuvonnen's Avatar
juha_teuvonnen
1. Secondary air injection injects air into the exhaust manifold to oxidise the carbon monoxide (CO) to carbon dioxide (CO2). Consequently it has nothing to do with AFR.
2. Your engine could be running lean at WOT for many reasons:
- too much air (leaking intake manifold seals, etc.)
- not enough fuel due to either mechanical problems (plugged injectors, etc) or electrical problems (for example TPS sensor malfunctions, so the ECU never gets to know that engine is running WOT and does not enrich the mixture appropriately).
What codes is the ECU throwing? Any mods?
Old Apr 6, 2008 | 04:43 PM
FRCTony's Avatar
FRCTony
What AFR?
Old Apr 6, 2008 | 05:00 PM
PewterMetallic98
The car is not running lean. It is running pig rich. AFR of 10.5 at WOT. The only code it has is the Secondary Air Injection malfunction code.
Old Apr 6, 2008 | 05:20 PM
ZeeOSix's Avatar
ZeeOSix
Your first post eludes to lean running, your last post eludes to rich running ... what is it?
Is the car modified?
As aready said, the secondary air injection code doesn't effect AFR.
Old Apr 6, 2008 | 05:22 PM
PewterMetallic98
Sorry! It was running very rich at WOT. Car is basically stock. Mods listed in my sig.
Old Apr 6, 2008 | 05:37 PM
ZeeOSix's Avatar
ZeeOSix
You're probaby seeing the normal "pig rich" AFR that these cars typically have from the factory.
How was the AFR measured (accurately) ? Wide band O2 sensor used by a shop that knows what they're doing?
Old Apr 6, 2008 | 05:40 PM
PewterMetallic98
Originally Posted by ZeeOSix
You're probably seeing the normal "pig rich" AFR that these cars typically have from the factory.
How was the AFR measured (accurately) ? Wide band O2 sensor from a shot that knows what they're doing?
Yea, it was a wide band 02. It was put in exactly as it should. I heard they come from the factory rich but that had me going . I wish I could post my dyno sheet but I don't have a scanner.
To Secondary Air Injection
