HVAC temp sensor
Old Apr 6, 2008 | 11:48 AM
Motohead1's Avatar
Motohead1
Default HVAC temp sensor
Hi all new here I just picked up a 00 FRC and Im trying to fix the little things before the mods begain.
Now what is frustrating is I searched the other day and found the answer here in tech but now i caint find the post again. I hate to make anouther post but here it is. My dual climate control is showing a -24 reading so from what I have read this is caused by a sensor or bad wireing and it wont let my AC come on thinking its to cold. My question is were is the sensor located? Thanks!
Old Apr 6, 2008 | 10:34 PM
Motohead1's Avatar
Motohead1
I still caint find the original post. BUMP.
Old Apr 7, 2008 | 12:55 AM
slplank's Avatar
slplank
I'm no expert on this but since no one else has offered help I can tell you there are two air sensors, one for inside air and one for outside air. The inside air sensor is located to the left of the ignition switch behind the small square slotted grill. I believe the outside or ambient air sensor is behind the front bumper near the lower radiator support bracket.
Old Apr 7, 2008 | 01:50 AM
BlackZ06's Avatar
BlackZ06
Post number 5 in this thread gives you the part number ... is this what you were looking for ????
http://forums.corvetteforum.com/show...mperature+HVAC
Old Apr 7, 2008 | 05:07 PM
Motohead1's Avatar
Motohead1
Thanks! thats it. Under the pass headlight.
To HVAC temp sensor
