clutch question
Old Apr 6, 2008 | 03:28 PM
cwalsh's Avatar
cwalsh
Default clutch question
I am having some clutch pedal issues. When upshifting around 6000rpm my clutch pedal is staying on the floor. I can pull the pedal back up and wait a few seconds or so and I have a pedal again. I drives fine at lower rpm shifts. I checked the fluid and it is pretty black. I thought about bleeding it but I think I might just go ahead and change the clutch master cylinder since the fluid is so nasty. I am thinking that it is leaking internally past an O-ring??? Any thoughts from anyone?
Chris
Old Apr 6, 2008 | 03:47 PM
STL94LT1's Avatar
STL94LT1
I would first try changing the fluid.
Old Apr 6, 2008 | 08:07 PM
cwalsh's Avatar
cwalsh
I am going that route first. I really hope it helps.
Chris
Old Apr 7, 2008 | 11:51 AM
jmzvet's Avatar
jmzvet
There is no definate cure for this problem other than installing an aftermarket clutch.
Old Apr 7, 2008 | 12:04 PM
'00FRC's Avatar
'00FRC
Check out this link from Ranger. It should help you with your clutch pedal woes.
http://www.rangeracceleration.com/Clutch_Care.html
Old Apr 7, 2008 | 02:49 PM
cwalsh's Avatar
cwalsh
I found this link last night on the forum going to try for sure!! My fluid is BLACK!!!
Chris
To clutch question
