Help with heads please NA set up
Looking for 2 choices
1 if no budget AFRs, trick flows?
2 On a budget Texas speed,patriot, etc etc
What do you guys think or suggest cam is
224/224 .581 .581 112 LSA
ls6 intake
UD pulley
LG streets, x pipe , no cats
borla stingers
halltech CAI
Pure street car will see track once a year at most
Reason i'm looking at the texas speed heads closely is i got my cam from them they could match my cam up but im sure any head company can, and at the price they are at i can also add a fast 92/92 set up at the same time for the price of the high end after market heads.
Could you tell me if anyone can guess what kinda gains i would see with
1. Adding High end heads AFR, Trickflow, etc
2. Adding ported 243 heads or 5.3 texas speed, patriot, aka budget heads
3. Adding a fast to the high end heads
4. Adding a fast to the budget heads
Thanks alot
That's just my gut feeling, but I'm sure the experts will chime in here.
The one advantage the AFR 205's have is they have higher velocity, which will give better throttle response and make a little more low end TQ. And they have a better combustion chamber design, which might help you get by with a little more timing. But you are going to have to pay for that little increase, compared to some ported LS6 heads. If you have the money, the AFR's is a better choice over any OEM ported head. But a set of ported LS6 heads will be much better than any LS1 stock head.
http://texas-speed.com/shop/item.asp?itemid=84&catid=20
I pm'd chris at ECS hope he stops in this thread before he goes home for the day
I felt the power differance between the AFR heads and the Patriot heads verses the money was not worth it to me.
I feel you get alot bang for your money with Patriot. If you intend on racing on the strip then go with AFR heads where 2 tenths of a second might make a difference.
What ever you decide good luck with your project.
Dennis
I'm not looking at a spreadsheet right now, but going off memory, with a 224ish cam, you will probably want to end up with a ~62cc chamber with .040" gasket to get your DCR/quench optimum to run all day on 93 octane, and a typical ported/big valve (but not milled) 5.3 head will fit that bill nicely.
Any aftermarket casting can do that too, if optimized (milled to spec) to get you to the DCR you want to achieve. with potentially better flow/velocity, and chamber characteristics..
Once you get your compression figured out, and know you want a 61cc head for example, then start looking for things like the smallest runner size packing the biggest flow #s, and the best forum feedback. Most people shopping aren't comparing $2800 heads to $1200 ones, but if you're truly in the market for any price, with the popular brands...you do tend to get what you pay for.
And always keep in mind advertised numbers is just that...advertised. The Big Mac you actually get never looks like the one you saw on TV.
Livernois Motorsports Stage 2 LS-Series "243" Heads
http://forums.corvetteforum.com/show....php?t=1963989
