Tire Sensor Install Question
Old Apr 7, 2008 | 01:31 PM
supergalaxy's Avatar
supergalaxy
7th Gear
Default Tire Sensor Install Question
I need to order replacement sensors for a 1999. The nuts and washers are sold separately. Are these lock washers/lock nuts of some kind that should not be reused? No big deal, but I can save $20 for the hardware if its not needed. If any doubt then I'll order all the parts. Thanks
Old Apr 7, 2008 | 03:14 PM
BlackZ06's Avatar
BlackZ06
For a 1999 here are the parts numbers you need ....
10438853 - sensor
25715243 - grommet
The nut can definately be re-used, but just in case it is
15234846 - nut
