2001 trac control and active handling not working.
Old Apr 7, 2008 | 08:21 PM
nightvision18's Avatar
nightvision18
2nd Gear
Default 2001 trac control and active handling not working.
I have a 2001 corvette and when i press the traction control button I get nothing. The same goes for the ride control when I switch to sport or proformance. I am not getting any codes on the DIC. When I start the car the trac light comes on so I no the light is not bad. I just replaced the relay for the pass door lock but I cant find this other problem. I see other people with this issue but they are getting a code. I checked fuses and the grounds look clean fom what I can see. Any help would be great. Thanks..
Old Apr 7, 2008 | 09:45 PM
MattZ28's Avatar
MattZ28
Pop the cover and check the wires going to the button.
Old Apr 7, 2008 | 10:01 PM
nightvision18
2nd Gear
I checked that and everything looks good. Put a tester to it and the harness is showing power.
To 2001 trac control and active handling not working.
