Help with my error code...P0137
Old Apr 8, 2008 | 02:31 PM
Lithium's Avatar
Lithium
Default Help with my error code...P0137
P0137
HO2S Circuit Low Voltage Bank 1 Sensor 2
ECM
DTC P0131, P0132, P0137, or P0138
I'm getting that error message. Anyone able to enlighten me as to what it might be? 02 sensors? Computer problem? I've done some research, but I can't pinpoint it. Thanks in advance guys!
Old Apr 8, 2008 | 02:35 PM
Lithium's Avatar
Lithium
Ignore, I found a ****-load of info when I clicked search W/o the "-" in p-0137
Sorry guys!
Old Apr 8, 2008 | 03:11 PM
Lithium's Avatar
Lithium
After doing research I have another question
When I first checked the code it was on a programmer so there wasn't a "h" or a "c". I just pulled the codes from the car via the DTC and it said my code was a H, but the light was still on. I reset it and it went off, obviously. What would be the reason why it was listed as a history code, but was still throwing a check engine light?
Old Apr 9, 2008 | 01:52 AM
BlackZ06's Avatar
BlackZ06
Many codes are programmed so that even when the problem is "fixed" the warning lamp still stays on. In the PCM a number of codes that set the "Check Engine" lamp will leave the lamp on until 3 ignition cycles with no error have passed. Even after the 3 cycles with no error have passed, and the warning lamp is turned off, the DTC can remain in the computer in an H status for 100 ignition cycles before the computer deletes it.
In large part this is done so that a problem that appears to be intermittent to the computer(s) appears to be "on-going" to the user. For example, suppose every other time you start the engine the PCM has a problem with sensor X, and turns on the "Check Engine" light. An "average" consumer is less likely to fix a problem that seems to "come and go" than a problem that appears to be "permanent".
Old Apr 10, 2008 | 10:41 AM
Lithium's Avatar
Lithium
Thanks!
So, it's been two days now w/o the car throwing that code and the check engine light has not come on. Does that mean the sensor is fine and just hit some sort of fluke or is it still a good idea to replace it?
Old Apr 10, 2008 | 11:20 PM
BlackZ06's Avatar
BlackZ06
Thanks!
I'd just keep on going. It's possible it was a "glitch" .... other possibility is the O2 sensor is getting old. If the error code returns, and clearing it only makes it go away for a day or two, then I'd consider diagnosing the problem further.
Old Apr 12, 2008 | 10:48 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
exactly
http://www.gearchatter.com/viewtopic10068.php
To Help with my error code...P0137
