code c1281
Old Apr 9, 2008 | 03:18 PM
kid81's Avatar
kid81
Default code c1281
I read about code c1281 and understand its about the steering sensor...What will happen if I do not get if fixed right away??? Is this something that can effect the performance or driveability in a negative way??? If so, what could happen....thanks
Old Apr 9, 2008 | 05:22 PM
TM-Z06's Avatar
TM-Z06
Worst case scenario...... the sensor will trigger the EBTCM to apply braking to one of the front brakes. (I had this happen)
Replace it as soon as you can. If you're worried about it, turn off TC/AH and don't drive like a maniac.
Old Apr 9, 2008 | 07:38 PM
Bill Dearborn's Avatar
Bill Dearborn
If you have C1281 the Active Handling system is turned off until the code is cleared. Nothing will happen. An inadvertant action may take place if there is no code and the sensor has an error. This is a very narrow window of opportunity.
Bill
Old Apr 10, 2008 | 11:01 PM
kid81's Avatar
kid81
Is the sensor itself bad or does it have to be re-calibrated somehow by a scanner or such.. I believe that a mechanic shop may have done this when they put on a new balancer.... what needs to be done???
Old Apr 10, 2008 | 11:49 PM
Cscokd's Avatar
Cscokd
Bill will have the answer for you, so take his advice. If it were me, I would disconnect the steering linkeage and re-center the wheel. They probably had to remove the rack and pinion assy. to work on the pulley. If they didn't get it back exactly as it was before, then this could be the problem. Bill knows how to calibrate this most likely.
Old Apr 11, 2008 | 12:09 AM
BlackZ06's Avatar
BlackZ06
They screwed up and let the steering wheel rotate .... you're lucky they didn't damage the airbag clockspring .... From another post (SEARCH is a powerful tool ....)
If you have a VOM you can check it yourself. At the base of the steering column is the SWPS connection. Separate it and test the middle lt blue wire with the ingition on. It will read about .24V or 4.9V. If its low, unbolt steering connector in engine compartment and rotate wheel to the right 360 deg. If it is 4.9V make one turn to the left. Then retest Voltage. By the way, if you are big, it is easier to do if you remove the front seat--there is not a lot of room to work with in the cabin.
DO NOT turn the wheel except as listed above. Disconnect battery for at least 5 minutes before starting ANY work on the steering column. This will allow the airbag system to discharge and lessen the chance of firing the bag inadvertently.
To code c1281
