Clutch Question
Old Apr 9, 2008 | 05:03 PM
JeepJake's Avatar
JeepJake
Default Clutch Question
Though I do not need a clutch, but with my car at 94k how much should I expect to pay, the car is stock so I do not need anything crazy maybe stock/z06? I am not sure I called the dealer and they said around $2000, is that really how expensive it is, or is there somewhere in my area that does it cheaper?
Old Apr 9, 2008 | 11:16 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
That seems high. GM shows 10 hours to replace. To replace the clutch though you have to pretty much take the whole car apart.
Go here:
http://www.cajundude.com/c5techhome.htm
and check out 'Dope's Clutch How To Write Up'
If your stock and plan to stay that way, I'd go with the Z06 clutch DEFINITELY replace the slave as well and add the remote bleeder. Its also a good time to replace the rear output seals if they're leaking too.
