little tire help please?
Old Apr 9, 2008 | 06:55 PM
bcartman2's Avatar
bcartman2
Default little tire help please?
I am looking at TomZ's special on vredisten tires 275/40-17 and 295/35-18 for my 01 coupe, I am also putting on C5 Z06 wheels at the same time, will this combo throw off the speedo, how much? Also is there enough of a height difference to keep the ABS happy. Any other problems I haven’t thought of?
Old Apr 9, 2008 | 06:59 PM
02gt350's Avatar
02gt350
id go with 265's in front. and the tire height will be the same as your stockers. but even if its off a hair, the C5 has wheel sensors that correct the speedo....
Old Apr 9, 2008 | 07:32 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Same sizes that I'm using and ABS seems fine.
Old Apr 9, 2008 | 08:06 PM
bcartman2's Avatar
bcartman2
they only make 255 and 275, thanks for the info
Old Apr 12, 2008 | 02:18 AM
bcartman2's Avatar
bcartman2
OK one last question before I place my order, so with the 275/40's up front and the 295/35s in the back there is only about half an inch difference F-R so my car will see the back tire going faster than it should be in comparison to the front, so when I break traction my traction control will kick on sooner.....Right? Also both front and rear tire diameter are being changed, how will this not affect my speedo?...I lied, that is two questions.
Old Apr 12, 2008 | 06:41 AM
rws.1's Avatar
rws.1
In theory the T/C will kick in earlier... In practice you won't notice the fraction of a second it takes to spin the ~ 1 inch difference...
The stock tires rotate 780 times per mile
The new ones 797
If my math is correct... You will be going about 2% slower than your speed says...
Old Apr 12, 2008 | 01:13 PM
tiojames's Avatar
tiojames
I don't think you will have any problems. 1/2" to 1" difference in diameter is all that is needed to keep the ABS happy. Some on here report that they have gone to the same diameter front to rear with no problems.
Old Apr 12, 2008 | 02:55 PM
bcartman2's Avatar
bcartman2
thanks i feel better...
Old Apr 12, 2008 | 07:25 PM
C5FORFUN2's Avatar
C5FORFUN2
275-40 is too tall looking IMO especially compared to the short 35 sidewalls on back. I had 295-35's but changed to 255- 40 front and 285-40 rear. It fills in the wheel openings much nicer. (Also changed to 9.5x18 front and 10.5x18 rear) The diferential in size front to rear was almost exactly what the stock size was and we just changed the computer settings to correct the speedo.
Old Apr 12, 2008 | 09:39 PM
lawZ's Avatar
lawZ
You will love the Vreds.I have that size on my Z,they look fine.
To little tire help please?
