New motor coming!
Old Dec 12, 2001 | 06:36 PM
cjones's Avatar
cjones
Default New motor coming!
Just got off the phone ordering a 388 all bore from MMS. Going with Stage 3 heads and a 229 cam. Should make some decent power! ;-)
I'll post dyno sheets sometime in mid to late January.
Old Dec 12, 2001 | 06:39 PM
RajunCajun2001's Avatar
RajunCajun2001
Default Re: New motor coming! (cjones)
Sweet! Keep us posted! :cheers:
Old Dec 12, 2001 | 06:40 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
:eek: :cool: Enjoy! :D
Old Dec 12, 2001 | 06:55 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Damn! The kind of motor i want! :)
Old Dec 12, 2001 | 07:03 PM
2000^C5's Avatar
2000^C5
Default Re: New motor coming! (kewlbrz)
What numbers are you hoping for?
Old Dec 13, 2001 | 12:04 AM
cjones's Avatar
cjones
Default Re: New motor coming! (2000^C5)
Mike said he that an A4 vette made 440rwhp last week, I think the converter was unlocked. That was a 388 with the 229 cam. Not sure if it had cats or not. Mine will. If I can make 425 rwhp through the unlocked converter I'll be happy.
Old Dec 13, 2001 | 12:09 AM
2000^C5's Avatar
2000^C5
Is that Mike Norris?
Old Dec 13, 2001 | 12:30 AM
MelloYellow's Avatar
MelloYellow
Mike Morgan MMS. Same motor setup as mine pretty much if I ever save up my pennies, LOL. Tranny and TQ tube should be done this week. Wheels and Tires next. Will put engine on my Credit Card and ship mid-Jan as a worst case scenario here I believe.
Old Dec 13, 2001 | 12:35 AM
billiam01's Avatar
billiam01
Default Re: New motor coming! (MelloYellow)
MelloYello,
What are you doing with the TQ Tube and Tranny? Are they being modded?
Old Dec 13, 2001 | 12:38 AM
MelloYellow
Default Re: New motor coming! (billiam01)
Nope, just 2000 replacements for the stock ones that failed.
If GM had their act together I could have upgraded to the stronger '01-'02 shaft, but they wouldn't allow that part. Yet another reason I'm looking forward to not being under GM Warranty and going 3rd Party Ext. Warranty so I can choose my own parts.
Will be nice having the new pieces tho. Rare for a TQ Tube to fail. Bad Tranny probably killed it.
Old Dec 13, 2001 | 01:59 PM
C5Longhorn's Avatar
C5Longhorn
Congrats. Can you share some of the characteristics of a motor with these cubes?
Old Dec 13, 2001 | 02:16 PM
kewlbrz's Avatar
kewlbrz
Default Re: New motor coming! (rschiltz)
rschiltz,
The 388 All bore uses the stock stroke, with a 4.125 resleeved bore.
The best thing about an all bore is the unshrouding of the valves, and the quick stroke. The short stroke relative to bore, develops horsepower much more rapidly, and reduces sidewall loading substantially.
Bore over stroke is the only way to go for drag racing type performance.
The beuty of an all bore LS1/LS6 is that it is the ultimate bang for buck engine to build, and you can even spend less by using your stock crank and rods.
Expect 460+ Hp with nearly as much torque from a 388 all bore motor with the right heads/cam combo and all the bolt ons. More with programming and tuning.
[Modified by kewlbrz, 12:18 PM 12/13/2001]
Old Dec 13, 2001 | 03:15 PM
NoMercy's Avatar
NoMercy
Congrats!! Good luck and enjoy the new motor!! :cheers:
To New motor coming!
