Loose tips on NGK TR6 plugs
Old Apr 10, 2008 | 02:58 PM
Robiwan's Avatar
Robiwan
Default Loose tips on NGK TR6 plugs
I replaced my plugs yesterday and when I pulled out the old NGK TR6 plugs 7 out of 8 plugs had the tip unscrewed loose - 2 you could see a gap between top of the insulator and the bottom of the tip. I checked the new plugs for looseness, but they all felt tight. Should I use a drop of loctite to make sure they stay tight??
Should good plug wires hold the tips from turning?
TIA, Robi
Old Apr 10, 2008 | 03:32 PM
regorih's Avatar
regorih
Those NGK plugs are the old style pluge that the tips can be loosen, go buy a new set now, the plugs are re design and the tips are fixed and cant be taken off.
Roger
Old Apr 10, 2008 | 06:55 PM
Robiwan's Avatar
Robiwan
Thanks, that makes sense, since the new plugs I put in were not loose.
To Loose tips on NGK TR6 plugs
