Can this be accomplished on both sides without jeapordizing the ring and pinion setup? Do the sidegears interchange (one part number)? Is it a matter of pulling the carrier cap bolts and then the carrier and seperating that into two pieces like breaking down a ford trac-lok posi?
If you are talking about spiders gears I would say yes. As long as you reinstall the carrier shims correctly, it should be fine. You don't need to mess with the pinion gear so that is not a concern.
Thanks for your input. 1. I take it carrier shims control side to side ring gear movement, similar to a 12 bolt and other salsbury style GM diff's? 2. Once the cross shaft and spyder gears are removed from the larger carrier half, I'm assuming the side gears drop right out. Yes?
1. Yes.
2. Not sure. I can see that the side gears are splined to ends of the output shafts. I assume if you can remove both shafts, you can easily replace side gears.
Now I am curious why you are asking.
Hopefully someone who knows for certain will chime in...
Developing the capability of upgrading the output shafts; clutches and springs as well as side and spyder gears on my garage bench instead of giving that work away, would give me a broader range of lower geared differentials to make purchase offers on.
