K&n C5 1998
Old Apr 12, 2008 | 11:48 AM
victorpic's Avatar
victorpic
3rd Gear
Default K&n C5 1998
I just installed K&N Fuel Injection Performance Kit Second Generation 57-3020 an I am experiencing overheating, plus the thermostat is not opening at is temperature factory setting 195 degrees, has anyone solutions to this type of issue.
Old Apr 12, 2008 | 12:43 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
You may have accidently unplugged your fans when installing the filter assy.--also make sure the AIR pump suction hose is still hooked into the bridge somewhere--or it will run lean and possibly overheat-I would change to a 160* thermo anyway--
Old Apr 12, 2008 | 01:14 PM
hotwheels57's Avatar
hotwheels57
Old Apr 12, 2008 | 01:34 PM
MagRedConv's Avatar
MagRedConv
This is posted in General as well where I replied. What temps are you running? Do the fans kick on?
To K&n C5 1998
