M.a.f. Sensor Removal
Old Apr 15, 2008 | 11:56 AM
RON NARDONE's Avatar
RON NARDONE
Default M.a.f. Sensor Removal
What Would The Ls1 Do If The Mass Air Flow Sensor Was Removed.would It Run?
Old Apr 15, 2008 | 12:09 PM
slothy's Avatar
slothy
yes, but you will throw a code. - well i know it will idle, not sure if you could drive with out some type of problem.
Old Apr 15, 2008 | 05:46 PM
happa's Avatar
happa
You can get it tuned for that its called Speed Density. But its only worth it if your going to mess with the tune all the time. Basically if you change elevation or certain kind of cilmate your car will run kinda rough and act weird. Because its tuned on that one time and your MAF will change the cars computer when things change. Hope that makes sense.
To M.a.f. Sensor Removal
