Engine Warning Light on (SERVICE???)
Old Dec 13, 2001 | 03:31 PM
Budman's Avatar
Budman
St. Jude Donor '08
Default Engine Warning Light on (SERVICE???)
Yesterday the yellow engine light came on and then went off about 15 minutes later. Thought everything was OK. This morning it came on again. DO I need to take it in for SERVICE???? Anyone else have this problem? Will I hurt my baby if I keep driving it until I can get it in for service?? Any advise is appreciated. :rolleyes: :confused:
Old Dec 13, 2001 | 03:37 PM
B. Stewart's Avatar
B. Stewart
Default Re: Engine Warning Light on (Budman)
Pull the codes and let us know what you find. Here's how: http://97vette.com/howto/codes/index.html
Old Dec 13, 2001 | 04:04 PM
Budman's Avatar
Budman
St. Jude Donor '08
Default Re: Engine Warning Light on (B. Stewart)
B. Stweart,
Just went out to my car and did the code review. Here's what it said:
AO LDCM U1064 H which is Loss communication with BCM
A1 RDCM U1064 "
Any suggestions?
Old Dec 13, 2001 | 10:46 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
If the engine light came on,you should have a PCM code stored...Check'em again :yesnod:
Old Dec 14, 2001 | 01:44 PM
Budman's Avatar
Budman
St. Jude Donor '08
Default Re: Engine Warning Light on (C-5 TECH)
Thanks for the info. Finally figured out why the light came on. Checked my gas cap and it was loose. I filled up with gas and about three trips later the light went off and hasn't come on since. Thanks for the comeback.
To Engine Warning Light on (SERVICE???)
