engine lunched???
Old Apr 20, 2008 | 01:38 AM
wettvette's Avatar
wettvette
Default engine lunched???
engine making loud ticking noise comes and goes, temp was up to 240 not idling smooth. codes 10pcm po200 h ,p1571 hc, p1689 hc.
58sdm uh1000 hc. Now i do have my ebcm out and have sent it off to the abs fixer , so i dont know if any of the codes are to do with that.
There is a strong smell, petrol i think. can somebody shed some light on this for me please
just taken it for a drive now it not doing it????
Old Apr 20, 2008 | 03:34 AM
robrunwild's Avatar
robrunwild
Default You did check the obvious stuff right?
Belts, water pump, alternator, power steering? The smell could be a belt being burned from slipping when the engine got warm, when the engine was cooler it may have contracted and quit slipping.
Old Apr 20, 2008 | 06:01 AM
wettvette's Avatar
wettvette
car has 40000 miles on it, running fine , gave it hard throttle 1st, 2nd 3rd , running fine. 20 min before hand sounded like was not running on all cylinders and had a bent valve or something
Old Apr 20, 2008 | 07:25 AM
BlackZ06's Avatar
BlackZ06
I'd bet you have an engine ground strap coming loose. The P0200 indicates an electrical problem with the fuel injectors, and if the spark plugs aren't firing because of a ground problem that would account for the smell of petrol. A loose connection would also explain why the problem is intermittent.
If it is not a ground strap, check the spark plug wires to ensure they are on both the coils and the plugs correctly.
My money's on a ground. See Bill Curlee's excellent sticky at the top of this forum for information on the grounds.
See also the end of this thread to see how "easy" it is for a ground strap to come loose ....
http://forums.corvetteforum.com/show...post1565086097
Also notice above the pictures you are looking for grounds G106, G106, and G107 on the engine block as shown in the diagrams.
Old Apr 20, 2008 | 01:47 PM
aquaholic's Avatar
aquaholic
while your checking the plug wires, make sure you dont have a spark plug backing out on you.
To engine lunched???
