Anti-Squeal compound
as far as shims I can't remember f100% if they are already pressed on from the manufacturer or if you need to clip them on - pretty sure they are on the pad from the manufacturer...
).there are 3 copper parts .... two are what the manual calls "shims" ..... they sit at the top and bottom of the pad and, as jbauch357 said, provide an anti-clatter function. The other copper part is what the manual calls a "spring" and it presses the pad toward the the center of the rotor.
All of these, IMHO, are for positioning the pads, not for noise suppresion. Noise is more a function of pad material, with "high performance" pads more prone to noise than the "stock" pads.
Pad noise (squeal) is a vibration between the pad and rotor. The springs/shims and goop all help to reduce the vibration, but some pads will still squeal .... for example a Hawk DTC-70 pad is probably gonna squeal for the first few stops until the pads/rotors get up to about 500 degrees .... but then who would use a DTC-70 for the street ???
I would recommend you install new pads (of whatever type) with the GM supplied spring/shims. If you use the car for street driving adding the goop, as jbauch357 suggests, really can't hurt. If you plan to track the car (road course) I'd be concerned what happens to the goop at high temperatures ..... I'd leave it off unless someone can assure you that at high brake temperatures it doesn't catch fire, or liquify and become a lubricant on your rotors.
).I would recommend you install new pads (of whatever type) with the GM supplied spring/shims. If you use the car for street driving adding the goop, as jbauch357 suggests, really can't hurt. If you plan to track the car (road course) I'd be concerned what happens to the goop at high temperatures ..... I'd leave it off unless someone can assure you that at high brake temperatures it doesn't catch fire, or liquify and become a lubricant on your rotors.
Also I run the goop on my car, and it's performed just fine during lapping days, spirited road driving, auto-x, everything that I've thrown at the car. I use the orange brake quiet...
I am curious to see what other people think too...
