Parking Brake, need help
Old Apr 22, 2008 | 12:30 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Default Parking Brake, need help
I have this posted in the parts section, but since it's kind of an odd part, I wanted to get it on here as well in case anyone happens to have one, or is parting out a car.
I need the whole assembly handle and mechanisim that connects to the cable that comes up from the bottom . Mine is broke and not reparable. Go figure I am the only guy I know that has a C5 where the parking brake does not work!!
Any of you parting out cars, or any others that would have one please let me know.
Old Apr 22, 2008 | 03:02 PM
cliff_ford's Avatar
cliff_ford
This any good?
http://cgi.ebay.com/ebaymotors/03-Co...QQcmdZViewItem
Old Apr 22, 2008 | 03:12 PM
DPG's Avatar
DPG
St. Jude Donor '06
that should do it tank. good find cliff_ford.
I've never seen it happen, but its strange. The brake won't stay in the locked position and when you pull up on it, you dont hear the ratcheting sound. After pulling the assembly off, it looks like there is a spring broken that is keeping it from putting pressure on the claw that makes that clicking sound and will hold it on place once you go one click or more. Hope this makes sense. but there is no way takin it apart because its welded together and riveted.
Old Apr 22, 2008 | 04:45 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Thanks guys. I'll check that out.
Old Apr 23, 2008 | 09:57 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
bump
Old Apr 23, 2008 | 09:46 PM
boudreaux's Avatar
boudreaux
I had the same problem. So I replaced it with another one I got off a auction site.
To Parking Brake, need help
