what colour on the cable??
Old Apr 22, 2008 | 02:59 PM
n_brio's Avatar
n_brio
Default what colour on the cable??
what colour is it on the cable to the fule pump from the relay??
the picture is taken from the back side of the fuse/relay
many thanks fredrik
Old Apr 22, 2008 | 04:29 PM
BlackZ06's Avatar
BlackZ06
Your colors for the connectors don't match what my manual shows .... so I'm not sure what to tell you other than this ...
My 2001 manual shows the fuel pump supply voltage is fed from the underhood fuse block. Power comes from Fuse #13 (20 Amp) and is switched on by Relay 35. The power then feeds through a GREY wire located at position A12 on connector #3 (LIGHT GREY according to my manual - The other two large connectors are GREY and BLACK). Looks like it MIGHT be the white connector in your picture - GREY wire at lower left of the white connector ..... because wire colors above it match what my manual shows ..... A11 not used ... A10 is LIGHT GREEN/BLACK, A9 is DARK GREEN, A8 is DARK BLUE .... etc.)
A12 on the connector is a corner ..... the locations are numbered from A1 to A12 ... then B1 to B12.... to F1 to F12.
Old Apr 23, 2008 | 04:57 AM
n_brio's Avatar
n_brio
thanks you, i try that!
you are the best!!
To what colour on the cable??
