Have FE1 suspension, need ADVICE
Old Dec 14, 2001 | 07:35 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
Default Have FE1 suspension, need ADVICE
Where do I start to improve my suspenion? This is first vette I have owned and I really thought it handled well until you guys start talking about huge improvements with upgrades in just sway bars alone.
Been looking at Z51 sway bars or the Z06 sway bars from Ken but with so many specials going I can get the Hotchkis kit for just a little more.
Which will I notice biggest difference with: shocks or sway bars?
:confused: :confused:
Old Dec 14, 2001 | 10:26 PM
C5Cemo's Avatar
C5Cemo
Default Re: Have FE1 suspension, need ADVICE (John's vette)
I've got a stock Z51 setup but I'll give you my $.02.
Upgrading the shocks will effect overall ride quality whereas upgrading the swaybars will effect the car's handling ability only.
Aftermarket shocks have a shorter length of travel than the stock ones...the car will ride rougher as a result. Bigger swaybars will not make the car ride rougher under normal conditions but they will make the car handle better because of less body roll/lean.
I'd get the swaybars :yesnod:
Old Dec 14, 2001 | 11:02 PM
04BlueGoose's Avatar
04BlueGoose
I have a friend who had FE1, changed to Z51 and loved it. Then saw the
Hotchkis and had to have them. He says it is even better. His car is also
lowered 1" all around. Also GET RID OF THOSE DAMN RUNFLATS!!!!!!!
Old Dec 14, 2001 | 11:08 PM
MelloYellow's Avatar
MelloYellow
I thought Aftermarket shocks were stiffer, but had More travel while the shock itself is shorter, adding to the ability to travel. Longer piston might be what I'm trying to say. Longer pole, shorter shock.
Old Dec 14, 2001 | 11:17 PM
barryscott's Avatar
barryscott
Hey Now:
I was in your place when I got my 2001 coupe. I went with the Z06 bars and Bilstein Sports. Bought from Ken Fichtner off the forum. Good prices and service. Great improvement in ride and handling. Next mod to the suspension is Z51 springs. I would do both sway-bars and shocks if the funds would let me. Have any more question,just shoot me an e-mail. :cheers:
Old Dec 14, 2001 | 11:48 PM
vettvert's Avatar
vettvert
Default Re: Have FE1 suspension, need ADVICE (REDVETx2)
If you are interested in drag racing, then you don't want to change a thing. The stock FE1 suspension will launch much better off the line. If you are interested in auto crossing or road racing, then you may want to change your setup.
Old Dec 15, 2001 | 01:22 AM
CRUZMISL's Avatar
CRUZMISL
Default Re: Have FE1 suspension, need ADVICE (vettvert)
My advice, get rid of it all! Shocks , springs and swaybars. The whole set up is junk. I can say that cuz I had it too. The best value will be had with the Z06 swaybars and endlinks as well as the Bilstein sport shocks. This will be you're least expensive and will improve it dramatically. If you want to go overboard like I did then get some Z06 springs, ditch the runflats and get an alignment to Z06 specs. Now you're talking some serious cornering power. I get my CD player to stop when carving corners :eek:
Joe
To Have FE1 suspension, need ADVICE
