Gauge Cluster Issues
Old Apr 26, 2008 | 04:49 PM
Camaroguy22's Avatar
Camaroguy22
Default Gauge Cluster Issues
The tach and speedometer on my gauge cluster stopped working. My heads up display still shows the speed/tach. All of the other gauges in the cluster work fine. I am stumped...
Old Apr 26, 2008 | 11:38 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check for codes first. You may need to check the main connector on the rear of it which means nearly pulling it out.
Old Jun 15, 2008 | 04:55 PM
Camaroguy22
I am throwing these current codes:
P0430 TWC System Low Efficiency Bank 2 Current
P0803 1-4 Upshift Solenoid Control Circuit (M/T)
P0804 1-4 Upshift Lamp Control Circuit (M/T)
B0333 Outside Air Temp Sensor Open - outside air temp current
C2100 left front tire pressure montitor malfunction -
B0026 airbag
Old Jun 16, 2008 | 01:08 AM
Camaroguy22
Could a fuse be causing this?
Old Jun 16, 2008 | 05:13 PM
Camaroguy22
Bump!
Any opinions?
Does anybody have a walkthrough on gauge cluster removal?
Old Jun 16, 2008 | 06:02 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
http://www.vetteessentials.com/instr...zel_howto.html
I'm not sure why the Speedo and Tach are out, I doubt if it's the main connector if your HUD is functioning, do all the idiot lights still come on when you start the car?
Old Jun 16, 2008 | 06:23 PM
Camaroguy22
I didn't think it was the main connector either with all the other gauges working. All of the lights still come on when I turn it on. Also sometimes as I am driving the speedometer jumps from 0 to 55 and stays at 55 no matter what speed I am traveling. The tach always rests at 0. Sometimes the speedo rests at 0 aswell, if it is not doing that it is at 55. I have no idea.
Old Jun 16, 2008 | 06:34 PM
tstar's Avatar
tstar
Here's a shot of the back of the IPC, those two groups of four screws towards the center are the Tach and Speedo connections. You can also follow those tracks up and make sure the middle ribbon cable is seated properly in the mother board....
Tim
Old Jun 16, 2008 | 06:36 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
find someone local to help you, clusters are a joke to remove, fwiw, I would ck the ribbons as stated above
To Gauge Cluster Issues
