2004 Tire Pressures ?
Old Apr 26, 2008 | 07:06 PM
habib's Avatar
habib
Default 2004 Tire Pressures ?
I cant seem to find the info, on how much tire pressure in the Run flats front and rear. Please advise. thanks, habib
Old Apr 27, 2008 | 12:11 AM
my6thvette's Avatar
my6thvette
It's inside your driver door. 30 psi front and rear.
Old Apr 27, 2008 | 12:52 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Regardless of what tires you put on, you want 30-32 pounds. Pressure should be checked when the tires are COLD.
Old Apr 27, 2008 | 07:45 AM
rws.1's Avatar
rws.1
The vehicle door plate says 30 psi cold.
I prefer running just a bit lower 28 psi cold all around
Old Apr 27, 2008 | 08:28 AM
habib's Avatar
habib
Thank you all. habib
Old Apr 27, 2008 | 08:30 AM
mrm1149's Avatar
mrm1149
thats how I get my best even wear.
Old Apr 27, 2008 | 12:04 PM
Oldvetter's Avatar
Oldvetter
I agree with running 28 psi cold. ET, an EX-GM C5 Engineer, says 30 psi hot is the "sweet spot" and 30 psi cold is just the universal (liability) value. So hot pressures rely on the time of year and geographic location.
Old Apr 27, 2008 | 12:18 PM
bestvettever's Avatar
bestvettever
Default 28 psi cold is the best ride
Hi, I agree, 28 on the oem tires seems to give my 03 the best ride comfort, and tire wear.
Luck to all
To 2004 Tire Pressures ?
