Throwout bearing question
Old Apr 27, 2008 | 10:01 PM
PLANT PROTECTION's Avatar
PLANT PROTECTION
Default Throwout bearing question
Should the throwout bearing be spinning at all with the clutch out in neutral?
Old Apr 27, 2008 | 10:15 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Old Apr 27, 2008 | 10:17 PM
HP_Addict's Avatar
HP_Addict
yes, in our cars the throwout bearing lightly contacts the clutch at all times, thus spinning. It does not matter which gear it is in. When you push in the clutch the slave exerts force onto the TO bearing and dis-engaging the clutch.
Old Apr 27, 2008 | 10:18 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The throw out bearing is sprung loaded against the pressure plate fingers, so yes it will be constantly spinning.
Easiest way to check it is to open the inspection cover (bottom part of bell housing).
Old Apr 27, 2008 | 10:54 PM
PLANT PROTECTION
Thanks for the replies. Mine is, just making sure it was normal. I am troubleshooting a metal on metal grinding noise with the clutch in, making sure the throwout didn't self-destruct by constantly spinning. I guess I'll look at something else.
To Throwout bearing question
