Guys I am looking for a factory IPC book for a 00 FRC. Or do they only come on CD? If so where can I get a copy. BTW I already have a red set of factory manuals.
bump. So many views no replys. Is it posible there is no IPC and I have to go to the dealer to find part numbers? I hope not. Coming from the DSM world the manual and parts look up software is free. There has to be somthing similar for vettes.
If you quit using acronyms that nobody knows ( IPC ..... here in the Corvette world that is your Instrument Panel Controller ... and DSM ?????) and asked a plain English question "Where can I get a parts manual?" then someone can help .... like this ....
RIGHT click on that ..... you will get a pop-up box .... select "Save Target As ...." and then select where on your computer (and what file name) you want for it. You will need Adobe Reader to open the file as it is a ".pdf" format .... but most people already have this. This file is the GM parts manual for the C5.
WARNING - the file is about 120 Mb .... if you are on dial-up .... forget it.
