Tech Electrical Help
Old Dec 15, 2001 | 12:29 PM
Medriver99's Avatar
Medriver99
St. Jude Donor '07-'09
Default Tech Electrical Help
I have to wire some auxiliary lighting to the back section of my car.
I need them to turn on when the tail lamps come on. Where can i splice in
the power and ground, It should draw about as much power as the foglites.
Any Help appreciated.
Mike
Old Dec 16, 2001 | 06:23 PM
Medriver99's Avatar
Medriver99
Default Re: Tech Electrical Help (Medriver99)
ttt
Old Dec 16, 2001 | 07:59 PM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
I would power the lights off a relay triggered by the tail lights. Relativy easy.
Old Dec 16, 2001 | 10:18 PM
99HT's Avatar
99HT
The lights are driven by a relay in series with a switch in the tranny. Power goes through the switch AND relay. The relay is easy to replace if you overcurrent it, the tranny switch is probably hard to replace. I would try and protect the switch and use a relay.
To Tech Electrical Help
