Are ls7 clutch and ls2 flywheel zero balanced?
Old Apr 28, 2008 | 03:15 PM
T_Vert's Avatar
T_Vert
Default Are ls7 clutch and ls2 flywheel zero balanced?
I noticed you purchase the flywheel and the clutch assembly separately so I assume they have to be zero balanced as they are not sold in a kit and or marked to be bolted on any certain way. I see the flywheel has a blue stripe on the side where the starter ring is and the pressure plate has a bunch of purple markings but nothing indicating that it should be clocked any certain way. Anyone have any input on this?? Is this something that should be balanced together? If I recall my last one wasn't balanced.
Dave
Old Apr 28, 2008 | 09:17 PM
DPG's Avatar
DPG
St. Jude Donor '06
not sure if its balanced, but mine doesnt have any vibrations for almost a yr now.
