C5 transaxle connections
Old Apr 28, 2008 | 08:00 PM
TS99SS147's Avatar
TS99SS147
1st Gear
Default C5 transaxle connections
I have a 6-speed transaxle from a 2000 C5 that it going into a C1 along with an LS2. I want to verify that the four connections are the reverse lock out solenoid, the skip shift solenoid, reverse light switch, and speed sensor. Any help is appreciated. Also, if anyone has any recommendations for someone that can combine the controls for the engine, trans., and ABS brakes into one PCM and/or body control system, could you provide a name and number? Thank you, Toby.
