Vararam: can someone explain technically why it works and also....
Old May 3, 2008 | 09:14 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Originally Posted by vetfeva2
OK i am on the fence as well. The question that I have is, did all that got the Vararam also get a tune or was it Bolt and Go?
I have heard that vararams are bolt and go. You have to drive your car around at above 50mph for about 30 mins for the computer to adjust. Thats what I have heard anyways. But after reading in my owners manual the proper way to reset the computer is more elaborate with holding certain speeds, idles, stop and go etc etc. The whole procedure takes less then 15 mins but requires highway speed use of 65-70 for 5 min intervals.
If someone wants to know the procedure, Iam sure someone has it on their website. We just need them to provide the link or copy and paste it.
Old May 4, 2008 | 01:16 AM
motogib1's Avatar
motogib1
I installed the vararam in Feb. Had a lot of tuning done after header install but before vararam. Had 3.42 gears installed after vararam and car was tuned for the gears, not sure if any further engine tuning was done. Vararam says PCM adjusts after several miles, not clear if this is true for all combinations. Anyhow, the thing seems to work, car is pretty damn quick. I've run a 12.62 quarter at 113 mph with 60' way over 2.0 seconds. If I could launch I would easily bust 12.5 or lower. The stuff I've installed based on forum info works.
Old May 4, 2008 | 01:20 AM
motogib1's Avatar
motogib1
By the way, I used Cajundudes instructions for installation at: These are much better than the instructions that came with the vararam.
Old May 4, 2008 | 01:55 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
I agree. Throw out the Vararam install and use Cajundude's. While your at it, you should also buy it from him, he'll price match most anything. That's the least you could do for a longtime forum member (and later supporting sponser) who provides valuable instructions for those looking to install.
