Gm Uses Luk For Ls7 Clutches
INTERESTING.
GETTIN IT INSTALLED FRIDAY.
when we opened up the boxes. Lots of clutches to choose from out there. Mine is a daily driver so I think this clutch will do fine. I only have 432rwhp compared to some of the stronger vettes out there.
Thanks, Cory
just went through it! i got mine with the flywheel, clutch, pressure plate, flywheel bolts, and pressure plate bolts all for $472 shipped!
pretty sure you wont find a better price cause i did a lot of searching for the best price!
byunspeed.com
o. by the way the clutch feels great. feels like stock but if feels beefier.
still breaking it in though.
thanks, cory
thanks, cory
Product Name Model Price Total
1 x GM LS1 Pilot Bearing 14061685 $14.88 $14.88
1 x GM LS7 Pressure Plate, Disc & LS2 Flywheel
- GM Pressure Plate Bolts, M10 x 1: No
- RAM Alignment Shaft (1 1/8-26): No
- GM Hydraulic Clutch Main Cylinde: No
- GM LS1 Pilot Bearing: No
- GM Crankshaft Pilot Bearing, LS2: No
- GM Clutch Slave Cylinder/Actuato: No
- GM Auto Flywheel Bolts, M11x1.50: No
- ARP Pro Series Flywheel Bolt Kit: No
- ARP High Performance Series Pres: No
- LS7CLUTCHKIT $443.69
6 x GM Auto Flywheel Bolt (M11x1.50x23) 12553332 $2.58 $15.48
6 x GM Pressure Plate Bolt, M10 x 1.5 x 25 12561465 $0.56 $3.36
Sub-Total: $477.41
Total: $477.41
I got my slave off the bay. its a lot cheaper and shipping time wasnt too bad. also invest in the remote bleeder for the slave so in the future you can flush the complete system without having to get under the car! great little additive. You should make sure your clutch fluid is clean and clear, not black which leads to slave cylinder falure, its what happened to mine. You can get the remote bleeder from lapd.
heres the direct link and their on sale right now!
http://www.thelapd.com/index.php?mai...roducts_id=194
i was also told that unless im gona spin the clutch at 8000 rpm it doesnt need to be balanced. I didnt have mine done based on that and dont have any problems. no new vibrations or anything! actually, my car feels tighter and more solid than ever before, feel back in love all over again!
good luck, let us know how it goes!
Has been for years.
