C6 Z06 spring questions
Old Apr 30, 2008 | 09:35 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Default C6 Z06 spring questions
I have recently added c6 z06 sway bars to my 2000. I have had -04 z06 shocks in there for a few years now.
I was thinking that maybe I should complete the suspension upgrades and was wondering if C6 Z06 springs can or would fit on a C5. I know that the shocks & sways are a direct bolt on, but are the springs?
Has anyone attempted this mod? Is it a worthwhile swap? Does anyone have a chart listing the spring rate differences between the various suspentions available for the c5/c6?
Sorry if this question has already been asked & answered, I searched but didn't turn up anything.
Old Apr 30, 2008 | 09:40 PM
MagRedConv's Avatar
MagRedConv
I have C5 Z06 springs on the way, didn't find anything on C6 either. I did the same sway/shock you did as well.
BTW, I know where you can get a set of C5 for a good price; PM me if interested.
Old Apr 30, 2008 | 09:59 PM
jdmvette's Avatar
jdmvette
Night Owl for life
sending PM...
Old Apr 30, 2008 | 10:09 PM
chriswtx's Avatar
chriswtx
C6 springs do not fit C5s...
Old Apr 30, 2008 | 10:21 PM
jdmvette's Avatar
jdmvette
Night Owl for life
bummer! what is different about them?
Old Apr 30, 2008 | 10:32 PM
chriswtx's Avatar
chriswtx
the rear spring on the C6's (all) sit on a solid perch of the lower control arm, much like the front spring. The C5 uses a bolt and bushings that go through lower rear control arm. If you try and install a C6 spring on a C5, there in a hole in the lower control arm where it should be solid for it to mount properly.
Old Apr 30, 2008 | 10:37 PM
jdmvette's Avatar
jdmvette
Night Owl for life
so then i take it the c5 z06 spring is considered the pinnacle of the leaf springs available for the c5?
Old May 1, 2008 | 07:05 AM
byte_me's Avatar
byte_me
unless you go coil overs. I just did the 04 Z06 springs install on my 97 that had the base suspension...I believe you and I were discussing things in similar threads with other members...
The car feels 1000X better after everything is complete- I felt just doing shocks and sways was not going to give me what I wanted out of the car....its amazing how the parts all came together *I used C6 Z51 sway bars)
Look in the parts for sale section for a set of take off Z springs- I got mine almost new for $400. They go for $400 each new.
Old May 1, 2008 | 10:11 AM
chriswtx's Avatar
chriswtx
Z06 springs or alot of the racers use VBP springs...
http://www.vbandp.com/detail.aspx?ID=766
Old May 1, 2008 | 02:28 PM
jrmotorsports55's Avatar
jrmotorsports55
Anyone know how rough the VB&P Xtreme springs are on the street? I'm picking up a used C5 and want to auto-x it, but it wills till be street driven. Was thinking C5 Z06 springs, or the VBPs.
Thanks,
Jason
Old May 1, 2008 | 03:04 PM
MagRedConv's Avatar
MagRedConv
Check out the auto-cross board, probably some good info there.
Old May 1, 2008 | 04:41 PM
jrmotorsports55
Will do, thanks.
Jason
Old May 1, 2008 | 09:27 PM
jdmvette's Avatar
jdmvette
Night Owl for life
do all 4 years share the same spring?
Old May 21, 2008 | 07:23 PM
c3spdrcr20's Avatar
c3spdrcr20
Just for the record. I love the search function. I was wondering the same thing about the springs. I want to upgrade the full suspension on my 98 base coupe.
I'll just throw my question on this thread instead of starting a new one maybe it'll help someone else. Hope I'm not highjacking
I want to run:
* C6 Z51 sways with metal endlinks
* C6 Z06 shocks
* Lowered a bit on stock bolts (not going real low)
* C5 Z06 springs (after reading this thread)
* Alignment (after a few days to settle)
Do you guys see any problem with this set-up? (balance, steering, etc)
Are there any bushings that wear out on our cars?
What else is there to fully finish the suspension?
I have read and reread alot of reviews on the different parts. I know its mostly personal opinion. I've just never seen these all together. Also I want to try to stay away from aftermarket parts.
Old May 21, 2008 | 08:01 PM
c3spdrcr20's Avatar
c3spdrcr20
Old May 22, 2008 | 12:10 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
I really like my Hyperco composite springs, race setup for rear, and street setup for the front.
Old May 22, 2008 | 12:27 AM
kerryt1's Avatar
kerryt1
I want to run:
* C6 Z06 shocks
FYI, I believe that C5 Z06 springs are identical to the C5 Z51 springs in the front, and rears are different.
To C6 Z06 spring questions
Old May 22, 2008 | 10:11 AM
WKMCD's Avatar
WKMCD
Check with ROUSHRAVEN. He did a great setup on his car.
Old May 22, 2008 | 02:55 PM
rickkym's Avatar
rickkym
I found this chart somewhere, maybe on this site. When I put Z06 springs on my '97 it dropped at least an inch and rides much stiffer, YMMV. I still have the adjustable (f-45?) shocks though.
Code:
c5z06 frnt:526    rear:714
c5t1   frnt:582    rear:793
c6      frnt:420    rear:657
c6z51 frnt:526    rear:645
c6z06 frnt:531    rear:782
c6t1   frnt:582    rear:850
Old May 22, 2008 | 06:35 PM
c3spdrcr20's Avatar
c3spdrcr20
what is a C5T1?
