Car doesn't want to get low?
Old May 1, 2008 | 02:27 PM
MattZ28's Avatar
MattZ28
Default Car doesn't want to get low?
I lowered my car all the way in the front on stock bolts, and left 2-3 threads showing in the rear...still had some serious 4x4 stance going on.
Few days ago I cut 2/3 of the front bushings off, and lowered it all the way in the rear. Went a little lower, but there's still 2-3 fingers of wheel gap in the front!
I've driven 200 miles since lowering it, so I would imagine the suspension would have settled by now...any ideas?
Old May 1, 2008 | 03:12 PM
TrplBlk01's Avatar
TrplBlk01
I did them same and was not happy with it.
So I Bought C6 bolts and it's much better now!
Old May 1, 2008 | 06:52 PM
gunnerrun's Avatar
gunnerrun
Default lower
Did you measure a base so you could determine how much drop you have now? How far is the air dam off the ground? I may be the tire you are running is a low profile and so I believe you would have more wheel well space. Just a coupe of thoughts.
Old May 1, 2008 | 07:54 PM
MattZ28's Avatar
MattZ28
Well I just put on 275/35/18 Michelin PS tires today...but the car was on stock 265/40/17 GY Supercar tires.
Old May 1, 2008 | 08:33 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
To get the front any lower you would have to totally remove the adjustment bolts. I personally wouldn't recommend that, but there are plenty of guys that do it. I went with the C6 front bolts (lowered max) and aftermarket rear bolts. I am very happy with the look.
Post some pics if you can so we can see how much 4x4 action still resides.
Old May 1, 2008 | 08:46 PM
SilentFright
Tirerack.com has overall diameter for these tires at:
265/40/17 GY F1: 25.4"
http://www.tirerack.com/tires/Spec.j...4YR7F1SUPERCAR
275/35/18 Michelin PS: 25.7"
http://www.tirerack.com/tires/Spec.j...5YR8SPORTPS2V3
So the Michelins should take up .15" more space in the gap than the stock F1s' (12.85" radius compared to 12.7"). It isn't the tires.
Old May 1, 2008 | 09:01 PM
MattZ28's Avatar
MattZ28
Well honestly it doesn't look that bad to me...not sure I'd want to go any lower on a daily driver, I was just wondering what would cause this.
My car also had the highest stock height of any c5 Z06 I've seen.
Here it is before I ever touched it:
Old May 1, 2008 | 09:02 PM
MattZ28's Avatar
MattZ28
here it is now:
Old May 1, 2008 | 09:23 PM
dawiz's Avatar
dawiz
matt,
i removed my front bolts and cut the rear 2/3 and have 2-3 threads showing. i couldnt get the look i wanted by keeping the front bolts and not cutting the rear. i love how it looks now!
Old May 1, 2008 | 09:41 PM
MattZ28's Avatar
MattZ28
Damn that looks sick. Did you put anything between the front control arm and the leaf spring?
Old May 1, 2008 | 10:27 PM
SilentFright
Yeah your original ride-height is the highest I've seen on a Z. Are your springs stock?
Old May 2, 2008 | 01:13 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I just cut the front bushings and bought some longer bolts for the rear. I don't remember if they were 7/16 or 1/2 inch bolts but I bought them at the John Deere store.
Old May 2, 2008 | 07:24 AM
dawiz's Avatar
dawiz
not yet. i have two pices of rubber about 1/4 inch thick to put in there but havnt yet. i need to though cause i get a little noise from the drivers side.
Old May 2, 2008 | 07:56 AM
MattZ28's Avatar
MattZ28
Gotcha...and yes AFAIK my whole suspension is stock
Old May 2, 2008 | 08:11 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Matt, looking at your before and after pictures, I'd say that your car and my car started off the same height and are now at the same height. On mine, I went as far as I could go on the front adjusting bolts, and left 2-3 threads showing in the rear.
Yes, from a looks standpoint I'd like to be a little lower, however I didn't go any lower, as I have the active handling and didn't want to mess up the shocks.
Old May 2, 2008 | 11:10 AM
VETFEVER's Avatar
VETFEVER
It took a lot more miles than 200 before mine finally "settled" on the stock bolts with bushings left in. I would drive it a while longer and see if she comes down some more.
To Car doesn't want to get low?
