Pass window/door lock question
Old May 2, 2008 | 01:12 PM
HONDAFIXER's Avatar
HONDAFIXER
Default Pass window/door lock question
I have read all the passenger window/door lock threads and have a question.03 ZO6---When the passenger window stops working the door lock will work from the pass door switch but not from the driver's master switch.The pass window will not work from either switch unless I bang the door. What should I be looking for? Harness problem, regulator problem or door relays?---Thanks
