Brake caliper question
Old May 2, 2008 | 10:19 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Brake caliper question
Why do the bolts need to be replaced when doing the brake? Why can't you reused the bolts?
Old May 2, 2008 | 10:48 PM
David A's Avatar
David A
You are correct the factory service manual indicates to replace the caliper bolts. I re-use mine. I simply remove them way to often to keep replacing them. One of the reasons the factory instructs you to replace them is due to the new bolts come with the thread locker already applied. I clean mine throughly and apply high temp medium Loctite thread locker. The bolts appear to be stainless to me and don't appear to be torque to yield. I haven't had any failures or found any loose attachments. Perhaps it's ok to reuse or perhaps I'm simply lucky. Hopefully someone here will know for certain.
YMMV,
Dave
Old May 3, 2008 | 12:01 AM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Because it's easier for the GM service techs to just replace the bolts than to spend 3-5 minutes per bolt to clean them properly, and they just pass the marked-up cost of the bolts to the consumer...
Old May 3, 2008 | 09:43 AM
screw991le's Avatar
screw991le
Ok, so, clean them up and add a dab of lock-tite?
The bolts are like 60 bucks for all 4.
Old May 3, 2008 | 10:40 AM
JohnTheStigGalt
Yup. I wire brushed them, and then used a die to chase the threads. They looked brand new! High-temp medium strength loctite should do the job nicely.
Old May 3, 2008 | 10:57 AM
screw991le's Avatar
screw991le
Old May 3, 2008 | 12:09 PM
falcon5619's Avatar
falcon5619
GMpartshouse.com
$3.90 each for the caliper to bracket bolts
$4.69 each for the caliper to spindle bolts
So, the price will depend on what you are changing. If replacing brake pads with factory kit, then you get two of the caliper to bracket bolts included, you shouldnt' need any extra then since you only remove one bolt to change the pads. If you are replacing the rotors as well then you need the caliper to spindle bolts.
Old May 3, 2008 | 07:49 PM
rws.1's Avatar
rws.1
wire brush and or die.....
Old May 4, 2008 | 09:18 AM
screw991le's Avatar
screw991le
Originally Posted by falcon5619
GMpartshouse.com
Wow when I called Advance auto parts he told me 36 for the front and 24 for the rears. I hope he was quoting me pad prices by accident.
Old May 4, 2008 | 09:42 AM
BlackZ06's Avatar
BlackZ06
The GM Part numbers (which many stores cross-reference to their own numbers) are ...
14067559 - Caliper pin bolts (needed when changing pads) $5.27
14084051 - Caliper bracket bolts (needed when changing rotors) $6.33
The prices are the GM list price for the bolts.
Old May 4, 2008 | 11:25 AM
screw991le's Avatar
screw991le
To Brake caliper question
