Going Bald!!!!!!!
Old May 3, 2008 | 10:04 PM
MagRedConv's Avatar
MagRedConv
Default Going Bald!!!!!!!
I posted this in Audio as well and thought I'd do the same in Tech:
Just had the following installed in my '98 vert:
Alpine MRP 450 4 Channel Amp
Alpine SPX-17REF 6 1/2 Componet Speaker Set (w/crossovers)
PAC Adapter (using stock head)
All is in, the amp powers up, but nothing from the front speakers but a "flicker" from the drivers side. To boot, the AC comes on when the car is started or the radio is turned on.
I'm going freakin' nuts; has anyone encountered or have a solution for this situation? Thanks
Old May 4, 2008 | 12:08 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
The PAC adapters have (or used to have) a brown wire that is a signal reference ground. You may need to ground it. It is only used when needed and that is usually determined by whether or not you have engine noise. Make sure you have 12v at the amp for power and turn-on using the amp ground as your reference ground. Is that PAC adapter specifically for the Bose interface? You do have the Bose in your car right? Bose audio signals are different than all others and need proper adapters. Where is your amp grounded? It needs to be grounded to a clean chassis ground and nothing else. It should be as short as possible. The power is going directly to the battery or battery distribution under the hood correct? What are you using for your turn-on voltage to turn on the amp?? In these newer cars, you can't simply use a test light or VOM, find voltage and consider it a good voltage source.
Old May 4, 2008 | 12:13 AM
MagRedConv's Avatar
MagRedConv
Yes, have Bose, ground is as described, and power is running directly to battery. After speaking with a Forum member a minute ago on the phone the problem lies with the PAC, it's the wrong one. Thanks for the reply, truly appreciated!
Old May 4, 2008 | 12:23 AM
BLOWNBLUEZ06
That's what I thought. They have to be Bose specific. Still doesn't explain the A/C issue though.
To Going Bald!!!!!!!
