Hard wired
Old Dec 16, 2001 | 11:51 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Hard wired
Does anyone have their radar detector hard wired to the rear view mirror and not down to the BCM area? If so please advise as to which wires to pick up. Thanks in advance.
Old Dec 16, 2001 | 02:28 PM
Paradigm's Avatar
Paradigm
Default Re: Hard wired (Grumpy)
I hope someone has done this and answers this post. If not, I'll give the hardwire-to-mirror a go myself, but I hate being a pioneer.
Old Dec 16, 2001 | 02:38 PM
JohnS's Avatar
JohnS
I went the BCM area route. It wasn't that hard and wouldn't show any more exposed wiring than wiring to the mirror. Besides, there is wiring provided at the fuse box specifically for accessories that is on its own fuse and thus eliminating the need to cut/splice into wiring that wasn't meant to be cut into.
JohnS
Old Dec 16, 2001 | 02:56 PM
Grumpy's Avatar
Grumpy
MONARTOR
Default Re: Hard wired ('98 Six Speed)
Idid a search prior to posting and this is what I found that made me wonder: http://forums.corvetteforum.com/zerothread?id=149767
larryh is the guy, last poster in the thread
Sent him an e-mail but no answer yet
Old Dec 16, 2001 | 03:24 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Under the passenger side floor panel, there is a hot wire tucked inside. Run it where ever!
Old Dec 18, 2001 | 02:34 PM
Grumpy's Avatar
Grumpy
MONARTOR
Default Re: Hard wired (wallstAL)
I went the BCM area route also. Had my mechanic solder for me as he does the prettiest soldering. Pulled the A pillar palstic off and it just doesn't quite line up and look at the othe rside. what's the correct way to reattach the plastic? gotta say 'tho you can't see the thing if you don't know whereto look......
Old Dec 23, 2001 | 12:38 PM
Paradigm's Avatar
Paradigm
Back to the top, in hope that someone has pioneered it. It looks like this should be straight forward given the rear mirror's location.
To Hard wired
